UHHH..
ORIGINAL: onepoint8tee
Would the fuse blow before the headlight in all cases?
I'll give you a call I think saturday after my brother left. You also got my number right ?
I need your #, will you PM it to me? I havent checked all fuses, but everything else works.. Ill have to check on the tail/brake lights though. the high beam works in it, but its just the low beam, so i think the wiring would be ok?
Is it easy to take the bulb out and see if it is blown?
there are at least 2 fuses for the headlights. A mini bus fuse (along the top of the fuse panel) and a regular size bus fuse. The mini Fuse is somewhere in the upper right hand corner. I don't remember where the other is. Search on Audiworld. I think that is where I found the fuse panel layout.
