Um what does the 1in2 little code on my milage tracker mean????
it's your service indicator light..it's programmed to automatically turn on at preset intervals...it pretty much means nothing if your car is no longer under warranty..what year is your car? on 98+ MYs you can reset it yourself
Try this: On you inst cluster you have two sticks sticking out. Key off, push the right one in, hold it and turn the key on, but leave the engine off. (here's the tricky part, works on older A6's) Now, PULL the left stick. Press the right stick again, the odometer should then say "INSP" and pull the left stick again.
Haventornasunder
Apr 21, 2005 05:39 PM
