Unusual vibration in gas pedal [and car] when driving at high speeds
Old Oct 23, 2006 | 06:27 PM
410ThirtyValve's Avatar
Default Unusual vibration in gas pedal [and car] when driving at high speeds
Things seem to be getting worse by the week....anyways, I've been noticing that as I am driving along in 5th gear, there is usually a rather strong and hard vibration felt in the car and especially the gas pedal, when I reach speeds around 120km/h-155km/h, regardless of my RPM or how much pressure I put on the throttle. To add to the confusion, [I may be wrong on this, but...] I don't recall this happening while in 4th [or any other gear], although I usually don't past 120km/h in 4th all that much. As well, there is no problem doing speeds lower than that in 5th. As I have just but the car a month ago, and am new to stick shift, I'm not sure if this vibration is normal, BUT I strongly doubt it is, b/c it is a luxury car, and also I had the exact same car, same year, same engine, but with tiptronic, (1998 Audi A4 2.8Q 30 Valve) and at speeds over 200km/h it was nothing close to as unstable. To clarify, the RPM's remain in regular ranges and never reach near the redline when the vibration occurs, and I have had my codes checked recently, with no errors showing [other than O2 sensors]. Any ideas???? [The vibration definetly seems unusual, however, just to be clear it isn't all that bad- its likebeing in a stock neon trying to push 200km/h, but it is definetly noticeable and sometimes loud]
Old Oct 23, 2006 | 06:39 PM
Default RE: Unusual vibration in gas pedal [and car] when driving at high speeds
In Addition; if it is in any relation to the above, my tires may be unbalanced and in need of some severe pumping b/c I have had trouble getting the to pump properly, so it may have to do with the tires.......but it seems unlikely.....
Old Oct 23, 2006 | 06:46 PM
onepoint8tee's Avatar
Get your wheels balanced. If it is not rpm related and only speed related, thats probably the problem. Unless your under cariage is coming lose (control arms/tie rods, etc.)
Old Oct 23, 2006 | 08:13 PM
CRAZYHAWK's Avatar
+1^
Old Oct 23, 2006 | 08:53 PM
S_R_N83's Avatar
ORIGINAL: onepoint8tee
I also agree
Old Oct 24, 2006 | 12:27 AM
AudiCross's Avatar
Defanitly. my tires were unbalanced. between 70-85 MPH it vibrated. take it in. its a cheep quick fix. and itll feel soo much better when its done.
Old Oct 24, 2006 | 02:53 AM
acetrebo's Avatar
ORIGINAL: JasonnosaJ
Actually, its very likely the cause of your trouble. And also the cheapest, first thing you would try when troubleshooting a problem like this.
kahale5000
Jun 22, 2014 07:48 AM
maouloud
Aug 7, 2012 01:09 PM
SrK
Nov 9, 2010 02:03 AM
2005AudiA4
Dec 21, 2008 08:59 PM
Quattro_1.8t
Apr 30, 2008 12:55 AM
