Updated #2, found a leak - losing lots of oil rather quickly
Old Mar 22, 2007 | 11:32 PM
  #31
DZA's Avatar
DZA
Default RE: Losing a lot of oil rather quickly
Maybe, I checked it really well and it looked in great shape but it looked like it had little white specks in the middle of the seal.
Old Mar 22, 2007 | 11:36 PM
  #32
Belligerenceā„¢'s Avatar
there really shouldn't be any issue with the seal, it's only 500 miles old. you'd notice if the seal was f*cked, it'be obviously torn or otherwise worn.
I'm stumped man, I don't understand how there could be no oil there, and then it magically appears. the only suggestion I can give you is to replace the filter, and see if that solves your problem.
Old Mar 22, 2007 | 11:42 PM
  #33
DZA's Avatar
DZA
I wish I had just bought another one anyways. Maybe I'm just weaksauce and didn't tighten it enough. Perhaps the leak comes and goes b/c it only happens under pressure and by the time I park it stops leaking enough to drip. But, before I added oil yesterday, I checked around the filter before anything else and it was bone dry. I'm more than stumped.
Old Mar 23, 2007 | 09:19 AM
  #34
DZA's Avatar
DZA
I'm starting to think I was just too sloppy with my oil. I didn't wipe down the filter after taking off the car and I always fill up the filter part way before I coat the seal with my finger. If I had oil out side of the seal, it'd have no where to go but down and out where I have my leak at the filter.
I'll be able to tell in a day or so when the oil gets brown in the engine but stays fresh dripping around the filter.
Old Aug 10, 2007 | 02:54 PM
  #35
andreigbs's Avatar
Member
Youcould have bent the thread for the oil filter, causing it to not seal flush. Maybe an oil cooler upgrade is in order. Also, when you check the oil, wait about 2-3 min. with the engine off and level before reading the dipstick. You might also have a broken dipstick guide, allowing the dipstick to go deeper in the pan than normal. And lastly, tell your M3 friend his car needs 10w-60 oil, not usually available just anywhere.
Doc Rizk
S4
Mar 11, 2013 07:42 AM
MC Hammered
Sep 24, 2008 01:58 PM
10SecS4
Jul 30, 2007 05:16 PM
10SecS4
13
Jul 24, 2006 07:03 AM
