Used ECU w/Giac
Old Oct 3, 2006 | 04:03 PM
afek's Avatar
Default Used ECU w/Giac
Hi All,
I am planning to buy a used ECU chipped by Giac. It is out of a 99.5 1.8T FWD Manual, and my car is 99.5 1.8T Quattro Tiptronic. His ECU number ends with 557P and mine ends with 559C.
Using the serach option, I found out that these ECU's are swapable. But it requires playing with soft coding with Vag-Com.
My questions are:
1) Although the ECU's are compatible, do you think the Giac chip will make a difference? Do I need to have the giac chip reprogrammed to fit into a Quattro Tiptronic?
2) How can I change the soft coding with Vagcom (I have it), where can I find the prcedure? (numerical values to be entered etc.)
3) Has any of you did this before?
Thanks a lot.
ps: I have searched this, but couldn't find a direct answer.
Old Oct 3, 2006 | 04:08 PM
smokeU's Avatar
Default RE: Used ECU w/Giac
I would keep looking for the ecu that will match your car
Old Oct 3, 2006 | 06:04 PM
BadLuckAudi's Avatar
Im almost positive you can change it to work with your car with the Vag Com but i honestly have no idea how to do it
Old Oct 3, 2006 | 06:21 PM
18T's Avatar
18T
keep looking.
Old Oct 3, 2006 | 06:24 PM
brrman's Avatar
Many time the coding will not stick - I tried this with my 98.5 and the coding would not keep. The car ran very badly and the transmission was not functioning correctly.
Keep looking. Quatto vs FWD does not matter. But the tranny differences are a big matter.
Old Oct 3, 2006 | 06:35 PM
bluesnapper's Avatar
If it does not work with your car out let me know. I could be a potiental buyer. I'll have to check my ECU number.
Old Oct 3, 2006 | 07:57 PM
chaos92287's Avatar
would that chip work with a 98 1.8TQM???
mikekehler
Oct 6, 2009 12:38 AM
disbealig
Jan 5, 2009 01:25 AM
daness373
Feb 11, 2008 04:12 PM
Brandon2000s4
Sep 14, 2006 03:08 AM
dan
Jun 18, 2006 10:28 PM
