vaccum line question
Old Sep 3, 2004 | 11:29 AM
shon's Avatar
Default vaccum line question
JMG said that the blue line is the line he used for his boost guage, i was told to use the line highlighted in red for mine, will either work? and where is his blue line going to?
[IMG]local://upfiles/1877/ACCA341F3ED64D1D81CF6A306FA98F39.jpg[/IMG]
Old Sep 3, 2004 | 11:30 AM
shon's Avatar
Default RE: vaccum line question
well nm, it looks like both are routed to the same spot on the intake manifold... (on different sides)
i suppose ill go to the closer one for ease...
Old Sep 3, 2004 | 06:55 PM
1.8t20v's Avatar
I was just about to do this myself. The line with the red stripe is going to the fuel pressure regulator, I am not comfortable cutting into this one so I will probably not use this spot.
Im not sure where the line that the blue vacuum hose is running to goes. On my engine that vacuum line runs under the cover to the left rather than back under the manifold, I have a 99. I was going to use that line also, like in the pic. I thought that one went somewhere around the wastegate but not sure, I havent looked closely yet. Can anyone confirm?
Old Sep 3, 2004 | 09:24 PM
audiboy1618's Avatar
Theres one going of the manifold to the bypass valve, I think thats the clostest one to wastegate.
Old Sep 3, 2004 | 09:41 PM
shon's Avatar
well i went w/ the one that goes from manifold to FPR, as Overspun from AZ told me to.
but i have alot of vaccum, and when im not agressive on the gas, im in a vaccum, is this right or does my guage need to be zerod, when the car is off the guage reads zero, which leads me to believe it is zerod and thats how it will read
Old Sep 4, 2004 | 01:06 AM
David_K's Avatar
Tie into the black vacuum line coming directly off of your dv or bov
Old Sep 4, 2004 | 03:49 AM
shon's Avatar
i allready went to the FPR line, works fine, no leaks, 5-10lbs boost, in most cases its 5, but will rise to 10 at lower RPMs to compensate, then it drops to about 5 at higher RPMs
Old Sep 4, 2004 | 03:51 AM
shon's Avatar
btw, david your 1/4 mile time sucks...
i ran it in 0:56.xx in HS.... and that wasnt even great compared to my competition
Old Sep 4, 2004 | 06:13 AM
SlimChriz's Avatar
the place that the blue line goes to is conectected to the manifold,brake booster and the inlet from the gas tank vent..
I used the one thats highlighted in red some people say to use the one right on the front of the manifold that David was talkin about to your DV
Yeah vacuum is good when Idleing I get like 20-25 under idle vacuum is cause by the engine sucking air in and the air being restricted by the partialy closed throtle body vacuum=good gas mileage while driving
verbal kent
Apr 6, 2011 09:48 AM
jjcrt2
Oct 15, 2009 06:32 PM
Chico Audi
Dec 9, 2006 09:29 PM
perzianhustla
Sep 4, 2006 08:19 PM
rjplunk9
May 7, 2006 10:25 PM
