vaccuum leak issues *edited*
ok yeah, im a noob, i was a worried noob tho so i was looking for any reasonable answer, since he was an audi tech i figured id go with anything he said, i didnt but thats my bad, so lets just drop it, deal?
yeah, i know i need to replace it, does autozone sell something like that or do i have to get it through audi or a german parts supplier
Un-plug the valve, and run the engine, if it sounds like its sucking air its a standard vaccum line check valve and they are all the same.
If it is directly on top of the air box and doesn't make any noise when you dis-connect it its probably the N80 valve for the evapemmisions system.
it doesnt look like it is connected to anything electrical really, im not 100% sure on that tho. i disconnected it, ran it, kinda heard a hiss but not sure if it was something else, i didnt feel any suction on the hose tho, does that mean anything? i took a picture of the whole area where it is, maybe you can tell me
its a one way check valve. You need to replace it asap. Im sure you can get them at the dealer, but im not sure about a parts store, you should be able to. But the dealer would be a safe place to go to make sure you get the correct part and then install it yourself
thanks cincy, yeah, i ordered a replacement from the audi dealer in chandler (the closest one) next day delievery, cost me $30. do you think that will be the thing that is causing these codes?
