VAG Code and other issues......please help ordering parts tomorrow
Old Jan 27, 2008 | 05:41 PM
m5racer's Avatar
Default VAG Code and other issues......please help ordering parts tomorrow
ok so i have almost got my entier list of things i need to fix ready but i still have a few things poping up and would like to know what parts i need to fix them:
1. When ever i fill up gas the leaver clicks every 2L and i have to repump the trigger and start again. how do i stop the "full release" from happening when i fill up gas? what part would i need for this?
2. i keep getting this code after a few days from clearing my vag. it only happens when its really cold out. what is it and what do i need to fix it? does it need to be fixed or is this a common code
16826 - EVAP Emission Control Sys: Small Leak
P0442 - 35-10 - - - Intermittent
3. when i start my car it barely ever idols at 1,100rpm to warm up and then drops after about a minite. So when ever i start my car it jsut goes to 800rpm idol and its -5 out today. how can i fix this ?
thanks a lot for all the help again
Anthony
Old Jan 27, 2008 | 11:30 PM
auditech79's Avatar
Default RE: VAG Code and other issues......please help ordering parts tomorrow
1. If your using the same fuel pump try another one. If that still doesn't work you need a new fuel filler neck. (not cheap)
2. The EVAP system protects fuel fumes from escaping the gas tank and re-directs it into the intake. It could be your gas cap or a leaking line. Take your gas cap to a shop so they can check the cap with a tester to see if it leaks. Its not a system thats gonna make your engine run any different.
3. That sounds normal, if there aren't any codes, don't worry about it.
Old Jan 28, 2008 | 12:02 AM
m5racer's Avatar
alright thanks for hte help
Old Jan 28, 2008 | 12:06 AM
auditech79's Avatar
Oh just to make sure i didn't confuse you with the fuel pump, i meant the fuel pump at the gas station, not the one in the car.
Old Jan 28, 2008 | 10:02 AM
CRAZYHAWK's Avatar
16826/P0442/001090 - EVAP Emission Control Sys: Small Leak
Possible Symptoms
[ul][*]Malfunction Indicator Light (MIL) active [/ul]
Possible Causes
[ul][*]Evaporative Emission (EVAP) System leaking [/ul]
Possible Solutions
[ul][*]Check Evaporative Emission (EVAP) System Sealing
[ul][*]Check Fuel Cap [/ul][/ul]
Old Jan 28, 2008 | 10:25 AM
m5racer's Avatar
**** ya it is deffineatly the fuel filler neck, dam oh well to bad i always go to the full serve sunoco at the bottom the of street, hahahaa
chrono
Nov 12, 2011 04:17 PM
TurboB6
Jan 17, 2011 07:27 PM
shmeker
Jun 24, 2010 04:50 PM
Seventy7INa45
Mar 6, 2008 06:47 PM
fenderstrat1184
Feb 28, 2007 02:39 PM
