VAG-COM error code
Hey Guys,
Ok, so I used the ol' VAG-COM to find out about the CEL on my car, and this is the response..... does anyone know what this is, and how severe? Or, can I just clear the code and move on??
on a side note, looks like my battery died as well. How difficult is it to replace??
(2000 A4 1.8T)
error code:
Control Module Part Number: 4B0 906 018 Q
Component and/or Version: 1.8L R4/5VT G 0006
Software Coding: 07251
Work Shop Code: WSC 06335
1 Fault Found:
16795 - Secondary Air Injection System: Incorrect Flow Detected
P0411 - 35-10 - - - Intermittent
(2000 A4 1.8T)
error code:
1 Fault Found:
Many people have gotten that code when their stock Bypass/Diverter Valve was dying on them.
Also a possiblility that you could have a vacuum leak. Check all your vacuum hoses for cracks, leaks, etc...
ORIGINAL: t42ayj
Skibum, im a new Audi driver, how do you use the 'VAG-COM' better still what is it. And what is the 'CEL'
VAG-COM by Ross Tech
CEL = Check Engine Light
Since you're a noob, you might want to go here before you continue with this forum:
Start here.
Hey Brrman or Imolas4: How difficult is it to replace the bypass/diverter valve? (I haven't looked at my Bentley Manual yet), I'm just trying to get a feel for what type of job it might be. Where is it located?
ORIGINAL: skibum0019
1.8t dv location.
A 20 minute job doing it the first time. Just make sure you don't break the mini hose clamps unless you have zip ties or other clamps to replace them with.
I would rank it as a 1.5 on a scale of 1 - 5 (5 being most difficult) for a first timer
