VAG-COM error code
Old Jul 4, 2004 | 12:23 AM
skibum0019's Avatar
Default VAG-COM error code
Hey Guys,
Ok, so I used the ol' VAG-COM to find out about the CEL on my car, and this is the response..... does anyone know what this is, and how severe? Or, can I just clear the code and move on??
on a side note, looks like my battery died as well. How difficult is it to replace??
(2000 A4 1.8T)
error code:
Control Module Part Number: 4B0 906 018 Q
Component and/or Version: 1.8L R4/5VT G 0006
Software Coding: 07251
Work Shop Code: WSC 06335
1 Fault Found:
16795 - Secondary Air Injection System: Incorrect Flow Detected
P0411 - 35-10 - - - Intermittent
Old Jul 4, 2004 | 12:58 AM
brrman's Avatar
Default RE: VAG-COM error code
Many people have gotten that code when their stock Bypass/Diverter Valve was dying on them.
Also a possiblility that you could have a vacuum leak. Check all your vacuum hoses for cracks, leaks, etc...
Old Jul 8, 2004 | 11:08 AM
t42ayj's Avatar
Skibum, im a new Audi driver, how do you use the 'VAG-COM' better still what is it. And what is the 'CEL'
Old Jul 8, 2004 | 12:31 PM
ImolaS4's Avatar
ORIGINAL: t42ayj
VAG-COM is a computer software tool used to diagnose the engine and electricals within the car. It is used via your laptop and a link to the car's ecu. It's the best investment, dollar for dollar, that you can do for your car.
VAG-COM by Ross Tech
CEL = Check Engine Light
Since you're a noob, you might want to go here before you continue with this forum:
Start here.
Old Jul 8, 2004 | 06:40 PM
skibum0019's Avatar
Hey Brrman or Imolas4: How difficult is it to replace the bypass/diverter valve? (I haven't looked at my Bentley Manual yet), I'm just trying to get a feel for what type of job it might be. Where is it located?
Old Jul 8, 2004 | 07:37 PM
ImolaS4's Avatar
ORIGINAL: skibum0019
Here you go skibum0019:
1.8t dv location.
Old Jul 9, 2004 | 04:41 PM
skibum0019's Avatar
Thank you!!!
Old Jul 9, 2004 | 07:23 PM
brrman's Avatar
A 20 minute job doing it the first time. Just make sure you don't break the mini hose clamps unless you have zip ties or other clamps to replace them with.
I would rank it as a 1.5 on a scale of 1 - 5 (5 being most difficult) for a first timer
Old Jul 30, 2004 | 01:09 PM
shon's Avatar
i just have a problem even looking down past the turbo... or should you try removing the splash guards on the bottom and doing it from there?
Old Aug 1, 2004 | 12:04 PM
ImolaS4's Avatar
Yep... go up from below on the 1.8t engine.
