Vag not working
I just got my friends old ebay vag cable, and I downloaded the ross tech program for it. But when I try to test it it comes up saying port status: ok Interface: not found.
Any ideas?
Any ideas?
you need a driver for the cable
try here - its the driver for my cable but it should work. maybe
http://autonostics.com/pages.php?pageid=3
just install the file I think. I use com port 4 with my lap-top, yours might be different. Don't know if your radio is causing the problem? does your friend still have his audi - maybe you could test it on his car.
Follow these directions
http://www.ross-tech.com/vag-com/usb/usb-config.html
except when you go to step 6
go to the folder I had you DL earlier should be on your Desktop if you unziped it there. called winxp
select that file - then continue with the directions from ross-tech
good luck
good luck
