valve train???
Old Jul 1, 2007 | 11:02 AM
2000BoostA4's Avatar
Default valve train???
It came with a 3 Month/3,000 Mile Powertrain Warranty. It now makes a tapping noise when the vehical is started, it then appears to fade away once it is warmed up. If the vehical is shut off, then started, even thought it is warmed up, it still makes the tapping noise but doesnt go away completly, the sound is then very light. I had called the dealer and explained it to him, and he said it sounds like a valve is out of alignment. does anyone know what this is? or is it covered in this warranty??
Old Jul 1, 2007 | 03:31 PM
sean1.8t's Avatar
Default RE: valve train???
it's normal. all VAG(audi/VW/Seat/etc) engines due that.. just takes a minute for all the lifters to get primed with oil. then after that you can still notice a bit of tapping/noise. just how DOHC engines are
Old Jul 2, 2007 | 06:47 AM
david9999's Avatar
I'd have them check it out and at least have a record of the problem. Have them check the oil pressure.
Old Jul 2, 2007 | 10:03 AM
tfische12's Avatar
Sounds like the lifters. Normal for Audis. Have them check it out though to be sure.
NickBroderick
Apr 26, 2010 01:32 AM
gtzpower
Jun 10, 2007 11:20 PM
jereme
May 22, 2007 06:07 AM
GraffixWB
Dec 13, 2005 07:03 PM
