Vibration from my car
Old Nov 5, 2005 | 05:26 AM
apg96's Avatar
Default Vibration from my car
I have a vibration coming from my car, it felt like a flat tire and i pulled over and they were all fine. Could it be my tie rods that i have been told have going and within 5,000 mi should be replaced? The steering wheel actually twitchs too. And it gets slower as i slow down and faster when i speed up. It also pulls to the side (right).
Old Nov 5, 2005 | 05:41 AM
sandman's Avatar
Default RE: Vibration from my car
you think maybee you messed up your allignment in the accident?
Old Nov 5, 2005 | 05:44 AM
apg96's Avatar
well thats what i thought at first but it only started liek that on the way home from the hockey game. It was fine before all thsi and i have used the car all yesterday and all today. Its pretty loud and obvious so i dont think its was just i started noticing it. I also hit going straight no turned.
Old Nov 5, 2005 | 12:09 PM
david9999's Avatar
The cheapest would be that you threw a wheel weight and your wheel is unbalanced.
Old Nov 5, 2005 | 12:13 PM
Yuikio's Avatar
I guess TREs could do that.
Old Nov 5, 2005 | 10:40 PM
a4anonymous's Avatar
wheel bearings??
Old Nov 6, 2005 | 01:55 AM
trailboss's Avatar
Get a 4 wheel alignment and rotate your tires. If your alignment was knocked out of adjustment then you could be wearing your tires un even which can give some vibrations. Also a bent wheel will vibrate. Thats the cheapest way, if not that suspect your TRE's.
Old Nov 6, 2005 | 01:59 AM
dankhound's Avatar
Loose tie rods can act the way you describe but if youve hit somehting recently you may have also bent a wheel, driveshaft, etc.
Old Nov 6, 2005 | 02:05 AM
audiboy1618's Avatar
Could be those bad brakes.
Old Nov 6, 2005 | 04:17 AM
sammodon's Avatar
warped tires
