warm up
Old Oct 10, 2006 | 06:34 PM
mrdb85's Avatar
Default warm up
hey guys have a 1997 a4 1.8t qut/autotran, my heater takes a while to actually blow out hot air in the cold mornings, is this normal for car with 170k or is there some kind of maintenance i can perform to improve this?
BadLuckAudi's Avatar
Default RE: warm up
its normal man, it takes time for the motor to build heat
Old Oct 10, 2006 | 06:43 PM
acetrebo's Avatar
Default RE: warm up
Is this your first winter ever driving a car?
Must be.....but this just seems like a common sense to me....oh well.
Old Oct 10, 2006 | 06:47 PM
mrdb85's Avatar
Default RE: warm up
obviosuly not, but i was just curious becuse it take longer than other cars i have had and i wasnt sure if there was something that could fix this problem
Old Oct 10, 2006 | 06:50 PM
The Bishop's Avatar
Default RE: warm up
Make sure you have good coolant fluid, if it's old and sludgey it may not work as well.
Old Oct 10, 2006 | 07:10 PM
Default RE: warm up
well if it like takes forever you might have a stuck thermostat, causing the motor to warm up extreemly slow
Old Oct 10, 2006 | 11:28 PM
TDRILL's Avatar
Default RE: warm up
Take it easy on him, this isn't a stupid question. Drive a little Honda Civic and then compare it to say a 6.0L Dodge Diesel. That civic is going to heat up hella quick compared to the monster Dodge. Cars warm up at different rates.
Your engine needs to heat up before you feel any heat out of the vents. A broken thermostat could make it slower.
When you turn your heater on, coolant gets diverted to the heater core and then fans blow through that and into the car. Its possible that you have a clog in the passageway to your heater core or that the coolant is only trickling in to the core. This would slow it down considerably. Not changing the coolant enough and getting junk (rust etc) in there could clog up the heater core and severely limit the amount of flow.
Give a time estimate tomorrow and the temperature in the morning. A few minutes is totally normal. If it takes 15 minutes to feel any heat, you have a problem.
jbrown_a6_s line
Nov 12, 2012 10:23 PM
b7a4gray
Jul 28, 2011 01:59 PM
Nevalite
Mar 28, 2010 09:14 PM
audi2000
Aug 27, 2009 12:49 PM
CaliA4
Jan 5, 2006 12:53 PM
