warped rotor?
Old Mar 10, 2006 | 07:10 PM
StevenTownsend's Avatar
Default RE: warped rotor?
all good advice^.
and yeah do you feel tension on the brake pedal? like in succession with the squeeks?
Old Mar 10, 2006 | 08:25 PM
VB05's Avatar
i didnt use an impact gun to tighten. and no there is no noticeable feelings coming from the pedal.
Old Mar 10, 2006 | 08:56 PM
haveaseat's Avatar
Member
have u tried possibly bending back the backing plate? maybe its hittin the rottor slightly
Old Mar 11, 2006 | 11:57 AM
david9999's Avatar
Likely glazed pads.
Try a series of about 4 0r 5 heavy braking sessions.
in a SAFE place, bring the car up to speed and brake heavily 4 or 5 times and see if that helps.
Old Sep 30, 2006 | 05:35 PM
jkucz28's Avatar
you can just use an impact gun to crank them down either use a torque stick for the impact gun or just spin them down enough where the wheel sits flush then use a torque wrench after that
Old Sep 30, 2006 | 05:41 PM
Papachristou's Avatar
i was going to say too if they are warped, it wil usually make a vibration under braking.. squeaking could be they are worn down or not bedded properly or got some trash in there somehow?
Old Sep 30, 2006 | 07:25 PM
VB05's Avatar
yea this was resolved a long time ago, bad caliper piston...thanks though
Old Oct 1, 2006 | 01:22 AM
  #18
TDRILL's Avatar
wow, pretty old post brought back to life.
Hey VB, next time post what the solution to the problem was so everyone knows. For people that posted, they want to know if they were right. For people searching, they want to see what the fix is. They could have the same problem, they would read this whole post, but not find out what your problem actually was. Bad caliper piston was never suggested so they wouldn't know to check that out. Thanks
Old Oct 1, 2006 | 01:47 AM
  #19
VB05's Avatar
yea one of my caliper pistons died, so one brake on one side was doing all the work to make up for the other side being dead. So the pads on the good side worn down so fast that they were almost totaly gone.
Tom1691
B8 Models
Feb 18, 2015 10:37 PM
Nshudog
Aug 25, 2012 02:13 PM
TheBat
Feb 28, 2008 12:18 AM
chongboi
Oct 29, 2006 12:20 AM
StepUpProductions
Feb 7, 2006 11:02 PM
