washer motor fuse
Old Feb 7, 2007 | 02:44 PM
spectrum's Avatar
Default washer motor fuse
Do you think if the front bumper washer jets were frozen down that would blow the fuse? I lost 2 already!
Old Feb 7, 2007 | 02:46 PM
onepoint8tee's Avatar
Default RE: washer motor fuse
ya it probably would. They only work if your headlights are on, so if you are trying to spray your windshield with the lights on, the healight washers are trying to work too, if their frozen i think that would blow a fuse. Even if your windshield washer fluid is frozen in the lines somewhere- that would cause the motors to work to hard and blow a fuse.
Old Feb 7, 2007 | 02:51 PM
spectrum's Avatar
I wish i had some where to unthaw. Iwill have to wait for warmer temps to wash at night
Old Feb 7, 2007 | 08:50 PM
AudiTurbo's Avatar
Where is the fuse? thanks
Old Feb 7, 2007 | 08:52 PM
check the fuse panel?
Old Feb 7, 2007 | 09:08 PM
AudiTurbo's Avatar
I guess thats a great place to start.
Old Feb 8, 2007 | 02:13 PM
blueracer17's Avatar
It will cause a blown fuse, dealer mentioned it whenI was in for warranty work in November. I have since disconnected the headlight washer pump and filled the plug ends with dilectric grease. The pump is new, and they seem to have a short life. Besides all the headlight washer does is make a mess on an otherwise clean car. I think it' fuse #37 25 amp. OR 30 amp if it has been changed do to blown fuses in the past.
eric
www.shoponemotorsports.com
HulkB5
Jun 12, 2012 07:05 PM
SIDESHOW
Mar 2, 2010 11:07 AM
TeeterTawter
Nov 22, 2008 07:14 PM
yknits18
Jun 7, 2008 10:49 AM
jinsojoo
Dec 20, 2007 11:42 AM
