Water Pump
Old May 24, 2005 | 01:58 PM
Nightstalker's Avatar
Default Water Pump
anywhere I can find a water pump DIY? *** clown that did the timing belt before I bought it didn't do
the water pump.
Old May 24, 2005 | 02:00 PM
clconversion's Avatar
Default RE: Water Pump
what year is your car ? from 2000 and down they are external water pumps and do not need to be changed when you do the timing belt service
Old May 24, 2005 | 02:04 PM
It's a 98....
Old May 24, 2005 | 02:11 PM
part number 050121010cx external wp $161.52 Canadian
Old May 24, 2005 | 02:21 PM
cool thanks, but anywhere I can find out how to install?
Old May 24, 2005 | 04:54 PM
is it leaking are you having a problem with it ?
Old May 24, 2005 | 06:02 PM
No but my car has 80K on it and it just got a new timing belt for the first time so I am assuming it hasn't been
swapped out yet. I really don't feel like waiting until my water temp reaches redline.
Old May 24, 2005 | 06:12 PM
Jestnomen's Avatar
6th Gear
same procedure as the timing belt change...
http://www.audiworld.com/tech/eng35.shtml
http://www.audiworld.com/tech/eng31.shtml
Old May 24, 2005 | 06:36 PM
if its a 2001 and on 2000 and down it is external nothing to do with the timing belt change you really do not know much about these cars do you jestnomen
ORIGINAL: Jestnomen
Do I have to remove the timing belt and go through all that **** just to replace it? Man, I miss my nissan where all I had to do was take the belt off, loosen 4 bolts pop it off and viola! Here I have to take the whole damn front end off!
