waterfall in my car????
Old Jul 25, 2005 | 01:28 PM
pliddy's Avatar
Default waterfall in my car????
went in my car today.. started it up, and i heard something that sounded like running water..
i look for it, and its around the pasenger side.. around the floor mat is wet.. i think its coming from behind the glove compartment..
any ideas what it is?? thanks
Old Jul 25, 2005 | 01:36 PM
zskylar's Avatar
Default RE: waterfall in my car????
Sounds like the air conditioning drain tube is clogged. You need to look under the car and locate the drain tube and trying clearing it with maybe a wire.
Old Jul 25, 2005 | 07:37 PM
drkenan's Avatar
Not sure what year or transmission type your car is, but I seem to remember hearing somewhere that the triptronic computer is underneath the floorboard of the passenger side. If this applies to you, be REALLY careful because you definitely do not want to replace that sucker.
Old Jul 25, 2005 | 07:50 PM
pliddy's Avatar
its a 96 a4 quattro
brrman's Avatar
could be the heater core leaking.
Pretty sure the 96 didnt come with tiptronic.
Old Jul 26, 2005 | 12:42 AM
david9999's Avatar
The drain for the drip tray of the air conditioner is probably plugged. See the first response and stick a wire or wire hanger up the drip hose from underneath the car.
Old Jul 26, 2005 | 01:37 AM
lidonnit's Avatar
Not to sure but think the heater core is on the right hand side of the car (Drivers side in Australia). The 96' didn't come out with TipTronic so that will be fine, but if it is your heater core.... Ouch. Dash has to come out.
Old Jul 29, 2005 | 07:16 PM
ltcoljdf's Avatar
I had this problem, just got it fixed. Took it in to one dealer, they replaced my drain hose. Next day after running my ac and driving it was pouring again. So I took it to another dealer, they couldn't make the ac leak. I got my car back and drove it around and then it started leaking again so I took it into the second dealer again and showed them. It took them 2 days but they found out it was my evap. box not draining. Problem solved. hope that helps
Old Jul 29, 2005 | 08:38 PM
pliddy's Avatar
cost??
Old Jul 29, 2005 | 10:58 PM
david9999's Avatar
See notes above. It could have been fixed for free by pushing a piece of wire or straightened hanger up the drain hose. You know it is cleared when a gallon of water pours out.
