On the way to work this morning........
Old Aug 14, 2007 | 01:11 PM
ceelos's Avatar
Member
Default On the way to work this morning........
So, this morning I get into the car to go to work and the car doesn't start right away. It kinda struggles tocrank as like the battery was dying. But, if I continue and leave the key turned to try to crank it, it turns over. Volt meter reads where it should, did notice that the display on the dash would dim almost to nothing. Drove into work fine with no issues (25-30min ride 15min on highway). Now, I just left to lunch and the same thing, no cels but I did get a 4 bell chime. I assuming its the terminals to the battery or maybe thewater level is low. I haven't hadthechance to look at it yet (heckit day).The only thing I did to the car was vag the car on the weekend so I can open the windows with the remote. Any one had a similar issue? Appreciate your comments. Thanks
Old Aug 14, 2007 | 01:14 PM
CRAZYHAWK's Avatar
Default RE: On the way to work this morning........
If your still using the origonal battery, it may be time for a new one.
Old Aug 14, 2007 | 04:24 PM
hiwords's Avatar
try sum starting fluid to see if it's not ur fuel pump
Old Aug 14, 2007 | 04:33 PM
Belligerenceâ„¢'s Avatar
ORIGINAL: hiwords
ummm... this isn't your uncle's 77 firebird here, I don't think that's such a great idea.
Old Aug 14, 2007 | 05:09 PM
acetrebo's Avatar
Sounds like the symptoms mine had before the starter went out.
I thought my battery was going, but it turned out to be the starter. One day it just stopped turning over all together.
If it does, get a multimeter and test the wires at the starter. If you're getting 12volts at the starter terminals, but no cranky-cranky, then your starter is gone.
Old Aug 14, 2007 | 11:33 PM
Trey25's Avatar
starter fluid hahaha...Sounds like your battery is on its way out.
Old Aug 15, 2007 | 09:04 AM
railrunner's Avatar
check also to see that your battery cables are firmly attached.
Old Aug 15, 2007 | 09:17 AM
Jackyl124's Avatar
Had the same problem a month ago and turned out to be the battery..........Id do battery
Old Aug 15, 2007 | 06:38 PM
ceelos's Avatar
Member
Ok, I got home from work and checked the battery, and it was onlyreading 6volts. It also happens to be the original battery (issued Jun 02'). I tried to start it to go to Autozone but I think it final died because it would even crank(Glad I made it home). So, I got in the backup car (87' Ford Escort) and went to get the battery. I installed the new one and wa-la, the car started. Drove it into work with no problems. Glad it wasn't the starter, wonder what that would cost me. Thanks guys
tofast2belast
Mar 30, 2013 02:16 PM
v6cab
Aug 21, 2011 07:27 AM
SAudi
Sep 5, 2007 01:11 PM
JohnnyBravoA4
Dec 22, 2006 04:52 PM
