weird bumping
Old Sep 10, 2005 | 06:12 PM
Sichko's Avatar
Default weird bumping
hey guys i dont think this will make sence but... ill try, every time i go over a bump or run over a pot hole my rightside of the car seems to rattle it feels like something in the suspension may be broken but i cant seem to see it. if u have any idea it would help. (it is the not the engine monts, i got them replaced several weeks ago)
Old Sep 10, 2005 | 06:21 PM
miked's Avatar
Default RE: weird bumping
sounds like you have an issue with your control arms.
Old Sep 10, 2005 | 07:43 PM
david9999's Avatar
Tie rod ends
Old Sep 10, 2005 | 11:02 PM
sandman's Avatar
^^^^^^^mine did the same, it was the tierod ends^^^^^
Old Sep 11, 2005 | 04:12 PM
Sichko's Avatar
k thanks, any idea on how much that is to get fixed, and can this lead to any other problems
Old Sep 18, 2005 | 04:11 PM
Sichko's Avatar
ok, i have an appointment on tuesday to get this fixed anyone got a good idea on what the price will be? My machanic said it will be at the minimun 250, does this sound high?
Old Sep 18, 2005 | 05:45 PM
BFlan2001's Avatar
no, that does not sound right....if you can work a wrench, you can replace the tie rod ends yourself for 70 bucks, or 100 bucks if you want to get the upgraded heavy duty tie rod ends. i just replaced my driver side tie rod end two days ago, it took me about 30 minutes total...here's a link....i got my tie rod end from www.purems.com .... www.ecstuning.com sells the heavy duty ones, i recommend getting those instead of OE.
http://www.audiworld.com/tech/wheel29.shtml
Old Sep 18, 2005 | 09:36 PM
Karl's Avatar
Brian.. why didnt you just replace them both?
Old Sep 19, 2005 | 01:28 AM
BFlan2001's Avatar
the right side was replaced by my mechanic back when i did the tranny, it was way worse then the left one for some reason
PineBluffAK
Jul 1, 2013 12:42 PM
Audispwn
Jan 14, 2009 10:06 PM
cshelloween
Nov 2, 2007 02:07 PM
ByPopularDemand
Oct 25, 2005 12:20 AM
