Weird Electrical Issue?
Old Apr 15, 2007 | 02:10 AM
trevor51590's Avatar
Default Weird Electrical Issue?
Hey guys!
I was out driving my car tonight and noticed something funny. The dash backlight (the red that lights up the tach and speedo, etc) shines a bright red. Then I look down and I see it fade out a little, and come back. It continued to do this the entire way home. Does anyone have ideas? I thought if the dash bulbs were going they would just shut off. Thats why I think it could be some kinda electrical thing. Ideas?
Old Apr 15, 2007 | 10:18 AM
david9999's Avatar
Default RE: Weird Electrical Issue?
Check your voltage. It could be that your voltage regulator is going bad.
Old Apr 15, 2007 | 12:04 PM
My voltage meter is showing great voltage. Dont know if that helps you guys.
Old Apr 15, 2007 | 12:26 PM
david9999's Avatar
Voltage meter is a rough approximation. Check the voltage with a volt meter.
Old Apr 15, 2007 | 09:17 PM
I havent had a chance to check the voltage yet but I will. Could this also be the reason why when I press the lock button for my doors the locks go down very slowly?
Old Jun 12, 2007 | 09:25 PM
Update to the situation. When the dash lights fade, all of the other control backlights fade (heated seats, climate control, mirror pad). I noticed that when I push on the dash, the lights light up bright like they should. If I release my hand they fade off and start to blink again. What kind of connector is back there that is loose?
Old Jun 12, 2007 | 09:52 PM
david9999's Avatar
OK so maybe a loose ground connection somewhere. I know this isn't much help, but electrical problems are a PITA
Old Jun 12, 2007 | 10:16 PM
Possibly, could this be related to my issue of not being able to lock the entire car from the key via outside?. Any info on what to check would be appreciated!
Old Jun 12, 2007 | 10:42 PM
A4 Effort's Avatar
Fiddle with the little ****/handle that you use to adjust your clock. That little **** is also used to adjust the illumination of your gauges. If it's loose, or hasa short, thatthat could be causing your problems.
Old Jun 13, 2007 | 08:54 AM
kpatz's Avatar
This is normal. There is an ambient light sensor that changes the brightness of the cluster, radio etc. As the ambient light changes (from driving through shadows, sunlight changing angles etc.) the lighting will fluctuate some.
Audiquestion
Jun 3, 2013 06:09 PM
DanaB6
Jul 19, 2012 11:58 AM
lumend13
Oct 27, 2008 01:42 AM
mslug
Dec 24, 2007 04:53 PM
CheeseHead
May 14, 2007 10:47 PM
