Weird sound praying its not transmition, help please
So after going through some testing (That tube idea was great) I belive my issue is my turbo's wastegate. Would the sound I described make sence? SOunds like a bycicle, only happens when im not acceleraing, louder when im coming down from accelerating?
So whats the cheapest place to get a replacement wastegate for a K03 and if its not worth it whats the cheapest place to get a K04?
Thanks all.
Thanks all.
Ah yes turbos
Clicky little fellas...
Yeah there could be a problem there that would tick (rotating parts and all), but I know nothing about turbos.
Hopefully someone else reads this.
ORIGINAL: Jestnomen
Hmm you've had this noise for a year and you havn't had a mechanic look at it?? Does it vary with engine speed??
Ok just incase someone does a search and has a similar sound. My issue was that my K03 turbo's valve on the inside was loose and would rattle when the valve was supposed to be closed. This is why it only did it when I was not on the gas. I fixed it by upgrading my turbo to a K04. Hope this helps someone in the future. =)
jasmix
Feb 1, 2008 06:10 PM
