Weird squeak noise
Old Nov 29, 2005 | 02:08 PM
wack0's Avatar
Default Weird squeak noise
Hi,
I'm getting this annoying "squeak squeak squeak" noise from my car. It stops after driving around a bit, maybe after the car warms up. The squeak seems to be worse when it is cold outside. I think it may be coming from the wheels or the engine area. Has anyone had this problem? Also it only squeaks while driving, not sitting still.
Old Nov 29, 2005 | 02:46 PM
GraffixWB's Avatar
Default RE: Weird squeak noise
if it happens when you turn your wheel, it's prolly the control arms.
Old Nov 29, 2005 | 02:50 PM
dubiousmusic's Avatar
i have the same problem sometimes. its only when i make left turns. do the controll arms need to be replaced?
Old Nov 29, 2005 | 02:54 PM
inkydog's Avatar
There is a recall on the control arm I called the dealer yesterday and they told me the only recall outstanding on my car (99 a4 1.8t 5 speed) was a control arm check if no one has messed with it it should be covered.
Old Nov 29, 2005 | 03:02 PM
you have a 99 i have an 01. do you know if its a recall for the 01?
Old Nov 29, 2005 | 03:54 PM
north5995's Avatar
Well the recall was on mine and its a 00 so I don't see why it wouldn't be on your 01.
My control arm squeaks when I shift gears and go over potholes. Lookup the recall beside the search button at the top of the page.
Old Nov 29, 2005 | 04:44 PM
wack0's Avatar
Hmm it does not only squeak while turning, it squeaks non stop for at least 5 minutes. Maybe it is related to this recall about Tie Rods?
Defect Summary: Vehicle description: passenger vehicles. the tie rods of the steering assembly are protected on each side by a seal to prevent moisture and dust particles from entering the swivel bearing mechanism. it is possible that some tie rod seals may not seal properly.
Old Nov 29, 2005 | 05:03 PM
tman's Avatar
Yes, I am concerned about a squeek noise in my car too. A4 99 1.8. I was actually searching around on the internet about the noise and I found this forum and this particular problem. My noise is coming from the wheel somewhere. It could be brake related because when I apply the brakes it seems to fade away. Also, when I accelerate it will fade. It seems to be comning from coasting along at about 20 - 30 miles an hour.
cfiore34
B7 Models
Aug 20, 2010 06:54 PM
AZAudiA6Q
Nov 26, 2008 06:56 PM
michaelh305
Aug 7, 2008 11:48 AM
prohloff
Dec 6, 2005 01:37 PM
