Weird squeak noise
Hi,
I'm getting this annoying "squeak squeak squeak" noise from my car. It stops after driving around a bit, maybe after the car warms up. The squeak seems to be worse when it is cold outside. I think it may be coming from the wheels or the engine area. Has anyone had this problem? Also it only squeaks while driving, not sitting still.
There is a recall on the control arm I called the dealer yesterday and they told me the only recall outstanding on my car (99 a4 1.8t 5 speed) was a control arm check if no one has messed with it it should be covered.
Well the recall was on mine and its a 00 so I don't see why it wouldn't be on your 01.
My control arm squeaks when I shift gears and go over potholes. Lookup the recall beside the search button at the top of the page.
Hmm it does not only squeak while turning, it squeaks non stop for at least 5 minutes. Maybe it is related to this recall about Tie Rods?
Defect Summary: Vehicle description: passenger vehicles. the tie rods of the steering assembly are protected on each side by a seal to prevent moisture and dust particles from entering the swivel bearing mechanism. it is possible that some tie rod seals may not seal properly.
Yes, I am concerned about a squeek noise in my car too. A4 99 1.8. I was actually searching around on the internet about the noise and I found this forum and this particular problem. My noise is coming from the wheel somewhere. It could be brake related because when I apply the brakes it seems to fade away. Also, when I accelerate it will fade. It seems to be comning from coasting along at about 20 - 30 miles an hour.
Jmineses_201
Apr 20, 2015 04:54 PM
cfiore34
B7 Models
Aug 20, 2010 06:54 PM
