Weird traction problem, cel esp lights have codes
Ok so awhile ago I posted these codes and began to discuss the situation. Awhile back my car's check engine light came on. A few minutes later the car jerked and the ESP light came on. Now the problem is increasing, the car will bog down a bit then the ESP light will go off, the CEL stays on. After a minute the car jerks and the ESP light comes back on. This one is blowin my mind, needless to say im takin it to the dealer monday. Just curious if anyone had a clue to point me in the right direction to avoid dealer rape.
I have reset these codes with my code reader and they came back.
Codes with explanation.
16487
P0103
Mass or Volume Air Flow Circ High Input
17522
P1114
Bank1-Sensor2 Internal Resistant too High
18265
P1857
Load Signal Error Message from Engine Contr.
16487
P0103
17522
P1114
18265
P1857
P0103 could be the MAF.
P1114 could be a downstreamO2 sensor.
The ESP light should cause an ABS cell that you're not getting.
Are you using a VAG code reader? Have you read the third computer?
You'll need a VW / Audi code reader to get the ABS codes.
http://search.ebay.com/audi-code-rea...Zm37QQfromZR40
jpcallmotor
Jul 14, 2010 10:00 AM
grytsenko
Nov 19, 2007 06:18 PM
wes342
May 17, 2007 08:08 PM
