HELP cold starting problem, abs and traction control lights on
Old May 17, 2007 | 04:21 PM
wes342's Avatar
Default HELP cold starting problem, abs and traction control lights on
[hr]
i have a 2001 a6 2.7t q when the car is cold it has problems starting it
just turns over 3-4 times then starts. then the abs light and the traction control light comes on than i drive about 2 miles turn it off and back on it starts fine and the traction control and abs lights are off again.
if you could give me any ideas of whats going on that would be great.
thanks a lot.[/align]
Old May 17, 2007 | 08:08 PM
auditech79's Avatar
Default RE: HELP cold starting problem, abs and traction control lights on
Check the fault codes and post them, the cold start issue can be as simple as a ect sensor. As for the abs light going off its probably your abs control module, try communicating with it with a vag-com or a factory scanner, if it doesn't communicate the module is probably bad.
chucks6
Jun 14, 2012 07:33 PM
obryan44
Nov 5, 2011 10:20 AM
bornnation29
Mar 8, 2008 09:22 PM
3phil4
Feb 11, 2007 09:19 PM
tholman
Aug 14, 2006 03:35 PM
