Well, dyno numbers are out....
Old Jul 4, 2006 | 12:22 AM
quattrosedan's Avatar
Default Well, dyno numbers are out....
Well, I got the car dynoed on Saturday. I am pretty happy with the numbers, granted it was 100.1 degrees with 97 percent humidity.
I did three pulls.
First pull, at 14 psi, I put down 228whp, 221wtq.
Second pull, two minutes later, same setup, put down 206whp, 200wtq.
..... So I lost 22whp bc of heat soak.
Third pull, I upped the boost to 19psi, I put down 239whp, 229wtq.
So I figure that if I had done the 19psi pull first, I could have put down 260-270whp.
I am pretty happy with these numbers, considering how hot it was, and I still have the stock cat and smic. So once, those are upgraded and we get some cooler weather down here in FL, I will re dyno and hopefully get about 285whp with the gtrs setup. Let me know what you guys think.
Old Jul 4, 2006 | 12:32 AM
trailboss's Avatar
Default RE: Well, dyno numbers are out....
Sweet, what tuning do you have? Also are you on the stock clutch? Where did you dyno at in FL?
Old Jul 4, 2006 | 12:48 AM
juice88's Avatar
what turbo are u running and with what else?
Old Jul 8, 2006 | 02:15 AM
I dynoed at Central Florida Turbo in Orlando.
As for mods, all I have is:
-atp elim gtrs turbo/mika software
-atp 3" inlet pipe
-3" catback exhaust
-stock smic, stock clutch, stock cat
I was pretty happy with the numbers. I will do it again in the winter to see how things change once it cools down and I get a boost controller to run about 22psi.
Old Jul 8, 2006 | 02:19 AM
trailboss's Avatar
should set up a date and ill met you there in the fall winter. I need to do some more stuff to my car before i dyno it. Clutch new fmic, and i wanna go a full 3" turbo back.
Old Jul 8, 2006 | 04:08 AM
juice88's Avatar
do u think u could have gotten more numbers out of the Unitronic software?and whats a high, average boost pressure this turbo can run reliably?
Old Jul 8, 2006 | 11:08 PM
I don't know if unitronics has software for this turbo yet. I know they put a lot of work into the 2871r turbo kit, though, and it seems good. The gtrs turbo is efficient up to about 22psi. So with a good fmic, I would run 22-23psi.
Oh, and Trailboss, I would love to do some sort of meet in the fall. My two friends who dynoed this time would probably go too. They have an a4 w/ 270 whp and an s4 w/ 427whp. But I will probably have a diff turbo by then, Im looking into getting a t3t4, I just need to find something like Lemmiwinks for a non drive by wire. Where at in FL are you at?
Old Jul 9, 2006 | 12:35 AM
Beer Mod's Avatar
Nice pull
Old Jul 9, 2006 | 02:09 AM
trailboss's Avatar
Im in sebastian, an hour south of cocoa beach
Get this unitronic uses the same base file for the gtrs 2871r and the gt3071r
I plan on going the gt3071 or 3076 either with standalone or some chip tune either UNI or TAPP
Old Jul 9, 2006 | 04:16 PM
The gt30 series are nice turbos. You will love that setup.
08A4Sline
Aug 12, 2010 01:20 PM
TT225quattro
May 13, 2009 06:53 AM
scg87
Dec 14, 2007 11:10 PM
Cain_2001A41.8T
Aug 23, 2006 11:29 AM
1BADS4
Feb 13, 2006 02:23 AM
