What causes misfires?
Old Nov 9, 2005 | 01:37 AM
Fall0ut's Avatar
Default What causes misfires?
What is the cause of a misfire?
I had one and my brother had to replace a cyliner.
What could it be? Very fast accelaration?
Old Nov 9, 2005 | 02:43 AM
sandman's Avatar
Default RE: What causes misfires?
plugs, wires, ignition timing?
Old Nov 9, 2005 | 03:11 AM
VB05's Avatar
injector could be totaly clogged, that would cause a misfire...which is when a cylinder doesnt complete its job. So a totally blocked off injector could be minimizing the fuel goin into it and not getting enough gas to combust fully. Find a VAGcom or take it to a dealer, it will tell you if it is a misfire and which cylinder (if u dont kno it is a misfire for sure)
EDIT: i worked on a f150 at my shop with a misfire in cyl 5. could be all of the things sandman said plus injectors. Like we replaced the wire on it, still missfired, then replaced the injector and it worked. plugwire, plug, or injector is ur best bet.
Old Nov 9, 2005 | 04:14 AM
Railslider's Avatar
What about throttle body issues? Couldn't that also cause a misfire?
Old Nov 9, 2005 | 04:51 AM
VB05's Avatar
anything that would cause an incomplete combustion can lead to missfires. anything to do with air, fuel, and spark.
Old Nov 9, 2005 | 11:35 PM
trailboss's Avatar
Cracked, leaking intake mainfold, could have a leak at the TB - intake connection. Bad coilpacks, plugs, dirty injectors, the list can go on.
Old Nov 9, 2005 | 11:40 PM
juice88's Avatar
couldnt he put in a few bottles of fuel system cleaner, like gumout regane or lucas oil cleaner.
srosati
Jul 26, 2014 09:29 AM
vtraudt
Jan 20, 2013 01:22 PM
Mott Power
Sep 6, 2009 03:31 PM
RaFa
Feb 5, 2008 05:56 PM
khj677turbo
Aug 24, 2007 12:06 PM
