1.8T AEB - misfires
Old Jan 19, 2013 | 02:01 PM
vtraudt's Avatar
Default 1.8T AEB - misfires
Any suggestions how to tackle these codes?
Saturday,19,January,2013,14:00:00:36008
VCDS Version: Release 11.11.5 (x64)
Address 01: Engine Labels: 058-907-55x-AEBN.lbl
Control Module Part Number: 8D0 907 557 P
Component and/or Version: 1.8L R4/5VT MOTR HS D02
Software Coding: 06201
Work Shop Code: WSC 00001
VCID: 3D71816537FD06F00AA
7 Faults Found:
17604 - Oxygen (Lambda) Sensor Heater Circuit: B1 S1
P1196 - 35-10 - Electrical Malfunction - Intermittent
17968 - Maximum Engine Speed Exceeded: Engine Warranty VOID!
P1560 - 35-10 - -) - Intermittent
16716 - Knock Sensor 2 (G66)
P0332 - 35-10 - Signal too Low - Intermittent
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-10 - - Intermittent
16686 - Cylinder 2
P0302 - 35-10 - Misfire Detected - Intermittent
16686 - Cylinder 2
Readiness: 0000 0000
Old Jan 20, 2013 | 12:13 PM
MetalMan's Avatar
Does this one have the ICM delete? If not, just try moving the coil packs around, and if the misfire stays at cylinder 2 it's probably the ICM.
Old Jan 20, 2013 | 12:46 PM
vtraudt's Avatar
I saw a note about ICM delete somewhere. What are the benefits (for tune cars)? I assume the benefits apply for 1.8T as well as 2.7T (have a total of 4 of them in my fleet). If benefits are real, I may start converting them (and if cost are in check).
Links?
In the meantime, i took the spark plugs out yesterday, put new NGK 7 heat gapped to 0.028 in.
The old plugs looked ok, but found some oil on the boot on 3 of the 4.
Will run a scan again after some driving.
Old Jan 20, 2013 | 01:22 PM
MetalMan's Avatar
The benefits are great! Smoother idle, smoother powerband, in some cases better MPG and more power (due to larger plug gap), less wiring, fewer components to fail, and these coil packs are only about $20 each.
Do a Google search for "ICM delete" and everything that comes up will pertain to the AEB engine.
I'm running a 0.040" gap on my BKR7E plugs, using 06H905115A coil packs. Bought them from http://genuineaudiparts.com/parts/in...&siteid=214407
Usually you'll need to use something like 034 Motorsports adapters to run 2.0T coil packs on AEB or 2.7T engines. These run about $20 each (four for AEB, 6 for 2.7T).
srosati
Jul 26, 2014 09:29 AM
Mott Power
Sep 6, 2009 03:31 PM
RaFa
Feb 5, 2008 05:56 PM
khj677turbo
Aug 24, 2007 12:06 PM
Fall0ut
Nov 9, 2005 11:40 PM
