What to do with 2k?
Old Oct 21, 2007 | 11:45 PM
jacob300zx's Avatar
Default What to do with 2k?
I am purchasing a 99 A4 1.8t awd Monday. I want to replace the timing belt, clean the oil screen, and do control arms and wheel bearings. Is there anything else to do? Where is the best place to order parts? Ok, so I am figuring I will have 2k left for performance parts after I do the DIY service on my car.
I was wanting to do a chip, bov, fmic, and full exhaust. What would ya'll do? Do I need to install all my parts then tell them what I have when I order the chip? How does that work? Lastly has anyone experimented with a port and polish on the stock turbo? Please be detailed with what you would do. I am new to the Euro cars.
Old Oct 22, 2007 | 12:09 AM
A4speed's Avatar
Default RE: What to do with 2k?
chip just adjusts the timing and boost of the turbo, chip before or after doesn't make that much of a difference.
my first question is what are your hp plans/goal?
if your going to get a BT setup then you might want to wait on the chip/sw on your car.
Old Oct 22, 2007 | 05:09 AM
david9999's Avatar
Timing belt, front engine belts, water pump and thermostat.
Might as well do the cam seals as it only adds 15 minutes to the job.
Suck out the power steering fluid from the reservoir and put in fresh pentosin 11S. Do this a few times over the next couple of thousand miles.
Bleed the brake system and put in fresh DOT 4 brake fluid
Check the battery and top up with distilled water.
Change the gear oil in transmission and differentials.
Unless you have problems with the wheel bearings or control arms, leave them alone.
Whatever you spend, leave 1000 in the bank to take care of unexpected emergencies.
Depending on what you want to acheive, you will need to decide on what you want.
If you want moderate increase in power, a chip and exhaust will be good for about 200 HP give or take.
You wont need a FMIC unless you go much biger.
Old Oct 22, 2007 | 05:16 AM
Limbs's Avatar
seat covers. cash the rest into ones and treat us to some strippers!
Old Oct 22, 2007 | 02:40 PM
ironman's Avatar
18's CoilOvers Tint Etc Etc
Old Oct 22, 2007 | 02:43 PM
oneg's Avatar
put away for bt
Old Oct 22, 2007 | 04:41 PM
klum00's Avatar
ORIGINAL: david9999
Smartest answer on here. Honestly it's fun and all to spend money and mod your new toy, but keep some change in the bank for something unexpected....
Old Oct 22, 2007 | 05:19 PM
ImTheDevil's Avatar
Absolutely - I'd also say set aside the amount needed to cover your deductible in the event some sack-wrinkle hits you while you're driving. That way you're not high-and-dry without the ability to cover your part of the repairs.
