What does this code mean?
Old Apr 20, 2006 | 04:28 AM
brandons34's Avatar
Default What does this code mean?
I took the car to autozone today and they had this to tell me
P0116
has determined that the input from the engine coolant temperature sensor changed too little or too much for currnt engine operating conditions
Old Apr 20, 2006 | 04:29 AM
BadLuckAudi's Avatar
Default RE: What does this code mean?
your coolant temperature sensor is fucked, you need a new one, that would cause the shitty starting you talked about in the other post
Old Apr 20, 2006 | 04:34 AM
brandons34's Avatar
ORIGINAL: BadLuckAudi
i've been hitting the sauce pretty hard tongiht, can you put that in english/
Old Apr 20, 2006 | 04:37 AM
new coolant temp sensor, little thingy that tells your car how warm or cold it is
Old Apr 20, 2006 | 04:46 AM
brandons34's Avatar
but how can that prevent my car from running? why would it die?!
Old Apr 20, 2006 | 06:29 AM
because the car thinks its the wrong temperature, trust me it will do it, the sensor says hey car your cold you need to have more fuel to run and the car says hey no I’m not I’m warm what the hell are you talking about lil coolant temp sensor, and then the temp sensor is all well take that bitch and gives the motor the wrong amount of fuel causing it to sputter and die on occasion, it can also work the other way to if the sensor is saying hey your hot but the motors all nu-uh I’m cold and it gives it to little fuel and the poor lil motor dies
Old Apr 20, 2006 | 06:47 AM
lol I hope that makes sense
Old Apr 20, 2006 | 11:48 AM
north5995's Avatar
Dude, the part is like $5 here:
http://www.carpartswholesale.com/sto...l=A4%20QUATTRO
If its not it, at least you only spent $5 and narrowed down what potentially could be wrong.
Old Apr 20, 2006 | 02:28 PM
brandons34's Avatar
ORIGINAL: north5995
i checked out the site and couldnt find it anywhere
Old Apr 20, 2006 | 02:52 PM
techbod's Avatar
thermostat sticking fit a new one so the coolant temp sensor can read the signal properly
