what does this mean?
Old Oct 19, 2007 | 01:04 PM
EVOLA4's Avatar
Default what does this mean?
i ran my shadetree software the other day which is very similar to vag com and it pulled this error. A Camshaft position (bank 1) : timing over-advanced or syetem performance [sporadic]
does anybody know what this means, this is the second time this has happened.
Old Oct 19, 2007 | 01:08 PM
techbod's Avatar
Default RE: what does this mean?
code pls
Old Oct 19, 2007 | 01:11 PM
EVOLA4's Avatar
i can give you the shade tree code if that helps. It's 16395
Old Oct 19, 2007 | 01:19 PM
techbod's Avatar
[IMG]local://upfiles/12092/AB065CCAC64B40C09264DD3A58F0951F.jpg[/IMG]
Old Oct 19, 2007 | 01:24 PM
EVOLA4's Avatar
is that bad? or is it just something that happens from time to time due to the chip and upgrades?
Old Oct 19, 2007 | 02:42 PM
auditech79's Avatar
If its not hindering performance don't worry about it. I have never seen that fault code on a stock engine, probably a fault code from aggressive tuning.
Old Oct 19, 2007 | 03:41 PM
EVOLA4's Avatar
that's kinda what I figured. the weather here is starting to get colder so I need to put different plugs in soon too. I figured the timing is being affected by the extreme climates we have here. it goes from 50 degrees in the morning to 90 degrees in the afternoon
