What does your volt meter read? UPDATE! WIRING ISSUE - HELP!
You need to check the volt drop from the alternator to the battery, if you have the volt meter but not an ohm meter check the volt drop. How you do this is you put the red lead on your meter to the + charging terminal on the alternator and the black lead on the + on the battery. If the wire is ok it should be less than .5 volts. If its over 1 volt drop the cable is bad.
ORIGINAL: auditech79
Bingo - replaced the alt to battery cable and converted to a marine battery terminal
Idle - 13.8v
AC on 13.67v
Lights on 13.67v
Lights + AC - 13.5v
Auditech79 wins a cookie!
Idle - 13.8v
AC on 13.67v
Lights on 13.67v
Lights + AC - 13.5v
ORIGINAL: wood_e
Idle - 13.8v
AC on 13.67v
Lights on 13.67v
Lights + AC - 13.5v
Idle - 13.8v
AC on 13.67v
Lights on 13.67v
Lights + AC - 13.5v
