What does your volt meter read? UPDATE! WIRING ISSUE - HELP!
Old Jun 4, 2007 | 08:28 PM
auditech79's Avatar
Default RE: What does your volt meter read?
You need to check the volt drop from the alternator to the battery, if you have the volt meter but not an ohm meter check the volt drop. How you do this is you put the red lead on your meter to the + charging terminal on the alternator and the black lead on the + on the battery. If the wire is ok it should be less than .5 volts. If its over 1 volt drop the cable is bad.
Old Jun 4, 2007 | 08:57 PM
theguy1084's Avatar
ORIGINAL: auditech79
x2 If the batt and the alt are good the only place to lose power is the cable. no other ground would effect the charging process as said before. you can also test voltage drop on the ground side by going from the alt case to batt neg. Voltage drops are a better way to find high resistance than ohms. Vehicke must be running of course
Old Jun 4, 2007 | 09:34 PM
wood_e's Avatar
Battery + to alt + while running = 1.66v
plus the alt post was HOT so theres resistance there - time for a new terminal
Old Jun 4, 2007 | 09:41 PM
auditech79's Avatar
Cable and terminal just to be safe.
auditech79's Avatar
Old Jun 4, 2007 | 10:29 PM
wood_e's Avatar
True - I just need to find cable
Afternoon project!
Old Jun 5, 2007 | 08:39 AM
Black_97 A4's Avatar
i think mine is like 15-16..it seems kind of high but i dont know..its a new battery..
Old Jun 5, 2007 | 10:05 PM
  #18
wood_e's Avatar
Bingo - replaced the alt to battery cable and converted to a marine battery terminal
Idle - 13.8v
AC on 13.67v
Lights on 13.67v
Lights + AC - 13.5v
Auditech79 wins a cookie!
Old Jun 6, 2007 | 12:07 AM
  #19
auditech79's Avatar
ORIGINAL: wood_e
Idle - 13.8v
AC on 13.67v
Lights on 13.67v
Lights + AC - 13.5v
I like chocolate chip
Old Jun 6, 2007 | 12:19 AM
  #20
wood_e's Avatar
Seriously - I'll send cookies - PM me where
