what is a farad and how many?
Old Jan 6, 2007 | 03:49 PM
Worlddre's Avatar
Default RE: what is a farad and how many?
ORIGINAL: new2me
Most power caps say what they are good up too. But if you are worried about lights dimming this will not cure it. You need to upgrade your wires in the engine bay. Power and Ground to the battery, alternator, and engine to frame and/or to fire wall. You can either add wire to the existing wires or just replace with a larger awg. all together.
the only correct advice given in this discussion. A cap is the equivalent to puttinga bandaid on a broken leg. If you have dimming as a result of a large audio system then you need to ugrade your electrical system or do as the above poster said and upgrade the wiring in your engine bay often referrred to as the " Big 3".
