What Happened To My '98 2.8Q??? PLEASE HELP!!!
Old Apr 5, 2007 | 08:07 PM
ekal42o's Avatar
Default What Happened To My '98 2.8Q??? PLEASE HELP!!!
My car has 81,000 miles on it. Its a stickshift 2.8 Quattro. I am due for an oil change, but I doubt that is it. For almost a week now my car was starting up funny and it sounded like something was gonna give. Well it did, my car will no longer start up. It will click, but it wont turn over. When I tried to jump my car, it was unsuccessful, the jumper cables were on, but it wouldn't click while the cables were attached. Someone please help me determine what is wrong with my car. I'm scared to take it to a dealership and be hit with a $1000 maintenance fee. Does anyone know how expensive this might be?
Thanks A Lot... All help is needed
Old Apr 5, 2007 | 08:46 PM
CRAZYHAWK's Avatar
Default RE: What Happened To My '98 2.8Q??? PLEASE HELP!!!
Make sure thebattery cables are clean and tight. Is your battery fully charged?
Did you use good quality jumper cables?
Old Apr 5, 2007 | 11:03 PM
quattro/2.8's Avatar
did u check ur alternnator to see if it is faulty and check back with us
Old Apr 6, 2007 | 01:14 AM
The Bishop's Avatar
Starter...Starter...Starter...Starter...Starter... Starter...Starter...Starter...Starter...Starter...
Old Apr 6, 2007 | 01:45 AM
wood_e's Avatar
DEAAAAAAADDDDDD starter/solenoid
Old Apr 6, 2007 | 03:05 PM
Andyrew's Avatar
Try push starting it. If its the starter.. you'll know.
Old Apr 6, 2007 | 04:18 PM
ekal42o's Avatar
thank you everyone for your help... ill address your comments in order...
Crazyhawk- the jumper cables werent that great, but the engine didnt even click once the cables were attached... i dont know how to check my battery's charge and how can i make sure the cables are tight?
Quattro/2.8- how can i check my alternator?
TheBishop/Wood_E- my thoughts exactly
AndyRew- my cars wheel locks are on and the car is on a busy street, push starting may be a problem
as for my car... i plan to get it taken care of today (prolly wont cause im a lazy college student) so still your advice will be helpful...
thank you everyone
Old Apr 6, 2007 | 08:41 PM
david9999's Avatar
Check for codes. With the jumpers did you at least get a "click" of the solenoid switching?
Turn on your lights Are they OK? How old is your battery?
Either very bad battery, ignition switch, starter solenoid, or starter motor. Can you borrow a battery from another car and see if it starts?
Old Apr 8, 2007 | 11:23 AM
acetrebo's Avatar
Its probably the starter.
If you DIY, its about 175 for a lifetime bosch starter.
If you DIY, you have to loosen the A/C compressor bracket, and swing it out of the way to get enough room to remove it.
Dealer is probably gonna hit you for 500 or so.
Just roll the car down the street, and pop it into second gear. If it starts and runs, then its definitely the starter. If it still wont start, then its probably the battery/alternator.
wolverine_s4
Jun 17, 2008 01:49 AM
a4autocrossr
Dec 11, 2004 03:45 AM
