What kind of gas do you use?
Old Apr 24, 2006 | 03:22 PM
brandons34's Avatar
Default What kind of gas do you use?
And are the benefits of a supreme gasoline noticeable?
Old Apr 24, 2006 | 03:25 PM
Jeff's Avatar
Zombie Defense Force
Default RE: What kind of gas do you use?
ORIGINAL: brandons34
you need to be using that anyways. much better for your motor
Old Apr 24, 2006 | 03:30 PM
north5995's Avatar
Well if you have the 1.8T engine, you should be using supreme all the time. You will end up having engine problems if you don't as the owners manual tells you to use supreme. Higher the octane, cleaner it is and better combustion. I switched from 91 to 94 and noticed better gas milage and smoother idle.
Old Apr 24, 2006 | 03:31 PM
Jovian's Avatar
I always try and use the highest the stations offer but with recent prices I have been sticking to 91
PS dont use regular your car will ping like a mother*#&$er
Old Apr 24, 2006 | 03:32 PM
brandons34's Avatar
ok, when making the change i shouldnt mix the two, right?
Old Apr 24, 2006 | 03:42 PM
BadLuckAudi's Avatar
no you dont need to mix them, just start using the good ****
Old Apr 24, 2006 | 03:43 PM
north5995's Avatar
Making the change? No you don't have to mix or anything as far as I know. Its not like you are changing over from mineral oil to snythetic.
Maybe put some injection cleaner in your tank to help clean the crap out of your injectors.
Old Apr 24, 2006 | 05:03 PM
brrman's Avatar
You "can" mix them if you want (ie. you want to fill the tank with premium when you already have 1/3 tank of regular). But you don't need to.
The car won't ping much at all unless you're chipped. It will simply retard the timing to adapt - albeit at a crappy fuel efficiency.
Old Apr 24, 2006 | 05:46 PM
smokeU's Avatar
what's the best type of injection cleaner? seafoam? I think thats what its called...
Old Apr 24, 2006 | 05:49 PM
tip5's Avatar
93 oct if you dont use it ill kill you.
