What kind of gas do you use?
Old Apr 25, 2006 | 04:25 PM
  #31
Trey25's Avatar
Default RE: What kind of gas do you use?
91 Octane, slightly better gas mileage. My wallet takes a beating though.
Old Apr 25, 2006 | 04:29 PM
  #32
tip5's Avatar
he was jokin... Bubble bath soap is kickass beats c-16 by a long shot.
Old Apr 25, 2006 | 04:34 PM
  #33
99a4audi's Avatar
i use premium everytime
Old Apr 25, 2006 | 06:04 PM
  #34
amarh04's Avatar
ORIGINAL: tip5
93 damnit.
hahaha bro just use whats top of the line gas...it will pay off...my baby is a lease but i still use the good ****
Old Apr 25, 2006 | 06:09 PM
  #35
onepoint8tee's Avatar
I used regular for a couple months with no problems that i was aware of and when i got chipped i switched to 93...
Old Apr 25, 2006 | 09:17 PM
  #36
trailboss's Avatar
ORIGINAL: lbraasch
I feel like there is a lot of mis-information here...
First off... like stated before 100 Octane is not anything like a Nitrous setup. NO is like forced induction. gas is still just gas, regaurdless of octane level.
Increased octane reduces the temperature at which gasoline will ignite w/o a spark (temperature and pressure cause it). When running higher compressions, you need to run a higher octane level to prevent the gasoline from ignighting before the spark plug fires. If you have pre-ignition, it can be deadly for your car. This is heard w. a noticable ping sound, also known as knocking. If your motor is knocking, stop driving it. Increasing octane levels will prevent knocking. However, if you do not need a higher octane level, you're just wasting your money. If the manufacture recomends 91 octane, put in 91 octane to your stock motor. if you increased boost, or any other performance mod's, and you experiance knocking w/ your current gasoline, increase the octane. This is why when you chip your car, they recomend various octane levels. Octane does not increase performance, it allows performance increases. off the top of my head, the only car i know of that will allow an increase of boost based directly on the computer learning what octane you are running are the old sweedish saab turbos. The ECU could be manually adjusted to vary the knock sensor, thus you could change the boost rate/knock sensor level, etc. It would allow boost to climb until the knock sensor kicked in. Putting 100 octane or octane booster in to 91 in a stock motor will do only one thing. put a dent in you rwallet.
Thanks for all the auto zone tip of the month. FYI as said he was joking. If you were out of NOOB stauts or been around this forum for a while you would know that we all joke around especially when asking such a ...... question like this, when easily if he typed it in and searched it would come up of alot of information.
Old Apr 25, 2006 | 09:56 PM
  #37
murphy_boy_2's Avatar
I dont remember who said it, but it was someone on here. They said using lower grade octane is like feeding your baby crappy food.... I thought that was a pretty good way to looke at it. I always using the highest at the pump, which is usually 93oct, I mean would you rather use a couple extra bucks than have a major problem with your engine later on?
Old Apr 25, 2006 | 11:14 PM
  #38
lbraasch's Avatar
It's more of an issue of vet's joking around with eachother, and people who don't know any better taking it as the word of god. The person who asked the question has 15 or so posts. What makes you think he's going ot know any better? He couldn't even read the recomended octane level inside his gas flap. There is a reason why so many ricers will pour money into those "instant hp" octane booster kits at autozone, and it's because for some reason or another somewhere along the line, they just assumed/were told that more octane = more power.
I also ride sport bikes, which is squid heavin (squid on motor cycle = fast and furious ricer boy in car). People will put in/do the weirdest things thinking they're getting more performance. I've even read of someone putting in leaded jet fuel in their bike thinking more octane was just like a nitrous injection system. It's a common misconception that people make about octane ratings thinking that they'll get the extra power from their motors.
Old Apr 26, 2006 | 04:50 AM
  #39
bronxblaza117's Avatar
ORIGINAL: north5995
Higher the octane, cleaner it is
octane has nothing to do with how clean it is... all grades have the same "cleaness"... different engines use different octanes to resist knocking, which is bad for the motor... look at this thread over at a Toyota 4Runner forum... read
Premium Vs. Regular Fuel
Old Apr 26, 2006 | 05:18 AM
  #40
BadLuckAudi's Avatar
yea but a lot of the times even if its supposed to be the same the higher octane gas has been more thoroughly filtered and refined and is cleaner
