What oil for 2002 A4 1.8T
Old Nov 28, 2006 | 05:02 PM
techbod's Avatar
Default RE: What oil for 2002 A4 1.8T
0W/40 is the best but here are the facts
[IMG]local://upfiles/12092/FB3DCB12C0CC45E8A8A4AA67656276C1.jpg[/IMG]
Old Nov 28, 2006 | 05:21 PM
wood_e's Avatar
Shell Rotella Synthetic 5w40 might be a good choice.
Old Nov 28, 2006 | 06:48 PM
ken sloat's Avatar
Royal Purple will deliver greater fuel economy and POWER! It's all we use in our race engines, and in new cars I have seen up to 60 extra miles on a tank of gas.
Old Nov 28, 2006 | 06:51 PM
wolfdog's Avatar
From autoeducation.com:
Oil weight, or viscosity, refers to how thick or thin the oil is. The temperature requirements set for oil by the Society of Automotive Engineers (SAE) is 0 degrees F (low) and 210 degrees F (high).
Oils meeting the SAE's low temperature requirements have a "W" after the viscosity rating (example: 10W), and oils that meet the high ratings have no letter (example SAE 30). An oil is rated for viscosity by heating it to a specified temperature, and then allowing it to flow out of a specifically sized hole. Its viscosity rating is determined by the length of time it takes to flow out of the hole. If it flows quickly, it gets a low rating. If it flows slowly, it gets a high rating.
Engines need oil that is thin enough for cold starts, and thick enough when the engine is hot. Since oil gets thinner when heated, and thicker when cooled, most of us use what are called multi-grade, or multi-viscosity oils. These oils meet SAE specifications for the low temperature requirements of a light oil and the high temperature requirements of a heavy oil. You will hear them referred to as multi-viscosity, all-season and all-weather oils. An example is a 10W-30 which is commonly found in stores. When choosing oil, always follow the manufacturer's recommendation.
Wondering how you can save money and protect your vehicle at the same time? Consider switching to synthetic oil and changing your oil at greater intervals.
I think you have to consider what temperature your car will see while it has the oil you are going to use. If you change your oil in the spring and fall you may want to alter the cold and hot weights you use knowing the season that lies ahead. If you live on the west coast, you may not ever have to do that.
I once did oil changes many moons ago. Now I feel like 1/2 a man because I don't even know what I have, the stealership did it at my 50k check-up... ;-)
Old Nov 29, 2006 | 05:30 AM
18T's Avatar
18T
100% syntetic 5W40. its what the dealers use.
Old Nov 29, 2006 | 10:39 AM
DavidL A4's Avatar
03 1.8t w/tip - Have had good luck with Castrol Full Synthetic (anti-sludge) and live in New England as well.
Old Nov 29, 2006 | 04:52 PM
beefski's Avatar
Castrol Syntec 5w40. Any brand is ok as long as it meets the VW standards 502, 505. It should say it on the bottle specifically.
Old Nov 29, 2006 | 06:16 PM
  #18
comfort_racing's Avatar
WELL it sounds like with my climate i should run 5w-40. thanks for all your help guys!
Old Nov 29, 2006 | 06:24 PM
  #19
AudiTurbo's Avatar
Synthetic is the only kind you should run in these motors. They are bad for sluge, so stick to Synthetic.
Old Dec 1, 2006 | 12:15 AM
  #20
rdburnsiii's Avatar
There was a factory service bulletin about 1 year ago recommending Mobil 1 synthetic, 0-40w. I could be wrong, but I doubt any of us on this forum know more than audi engineers. My question is: How often to change the oil???
I'm a little skeptical of the 10k mile interval. While the factory would make proper choices about WHICH oil to use, it seems to me that they probably don't care if the engine wears out at 120,000 miles versus 180,000 miles.
