What is this plug? (brakes)
Old Nov 14, 2007 | 07:45 PM
LowA4's Avatar
Default What is this plug? (brakes)
I have the solid abs and blinking brake light but no pad light and I found this plug on both sides just sitting there unplugged. What is it? I don't want to rebuild my abs unit if this is the cause.
Old Nov 14, 2007 | 07:46 PM
FASTER's Avatar
Tech Slut
Default RE: What is this plug? (brakes)
eeeewww... get a new cv boot
Old Nov 14, 2007 | 07:52 PM
LowA4's Avatar
Got it yesterday, puting it on saturday.
hiwords's Avatar
well there are only 2 sensors that are in thatarea. wheel speed sensor and brake wear sensor. the speed sensor should be on the 10 o'clock of the spindle/hub.
Old Nov 14, 2007 | 08:06 PM
LowA4's Avatar
Speed sensor is hooked up. If this is for the pads then I wonder why I have now brake pad light on. Could it cause my abs lights to light up?
Old Nov 14, 2007 | 08:11 PM
hiwords's Avatar
when i put on new pads, the pads came with different connects than the ones on the car. i forgot which ones but one was round and the other was square. so wut i did was i plugged in the old pads and cut the wires that connect to the old pads. then i just spliced them together and that should solve ur problem. when i had my pad connectors disconnected, i had the same lights and the abs was kicking in way too early.
Old Nov 14, 2007 | 08:20 PM
LowA4's Avatar
Where would the pad plug go on the pad? I don't see anywhere for it to plug in. I'm guessing the previous owner had the brakes done with non Audi pads.
Old Nov 14, 2007 | 08:24 PM
hiwords's Avatar
the pad itself is supposed to have a wire embedded into it. if ur old pads or new pads neither have that, then just get sumthing to wire those 2 pins together
Old Nov 14, 2007 | 08:30 PM
Bogie's Avatar
Last guy to change the brakes used cheaper pads for a similar model w/o abs if there were no wires and connector hanging off the inside brake pad.
Old Nov 14, 2007 | 08:41 PM
LowA4's Avatar
Sweet, new pads are cheaper than an abs module but I'm going to try to jump those wires as the pads are new.
