whats the best intake to get?
Old Mar 29, 2005 | 01:34 PM
audihere's Avatar
Banned
Default RE: whats the best intake to get?
well then this isnt what this is bc it never connects to the exhaust.
Old Mar 29, 2005 | 02:01 PM
TomRitt's Avatar
eh I dunno then...its in a great spot for the air filter though
Old Mar 29, 2005 | 02:20 PM
audihere's Avatar
Banned
ya i know and its in the damn way of my hybrid bov too[:@] stupid emissions crap...i just dont know if i can delete it since it is hooked to my valve cover...i dont want it to over heat or something go wrong from deleting it.
Old Mar 29, 2005 | 03:11 PM
rs's Avatar
rs
isnt the 2nd pump for cooling down the turbo/turbos?
think in the 2.7tt setup it turns on when the car is turned off so it cools down the turbos properly. correct me if im wrong tho
Old Mar 29, 2005 | 03:32 PM
CheckMyVitals's Avatar
ORIGINAL: audihere
evoms cai is like 250 im sure lltek is like 200 and a giac chip is around 500. i know what he asked for im just trying to help him better his money. cai dont do things like they do for other cars ok. like u have all said before the stock setup audi uses is good and i think should be messed with last when ur lookin to mod.
surprisingly, not everyone out there can just up and drop down 500 for a chip. it's also no secret a chip has massive gains... but
a) he (and many of us) can't afford a chip
b) he's already planning on a chip, just wants to add in intake
ORIGINAL: TomRitt
off the shelf intakes are garbage. I had the lltek one and had noticable losses. Then I routed the filter down behind the foglight (im 99.5 so no secondary air pump), and there was a little improvement over stock, not very noticable though.
Negative?? that blows! think this is a standard for all CAIs on audis? did you have a heat shield?
Old Mar 29, 2005 | 04:53 PM
TomRitt's Avatar
I'm pretty sure the secondary air pump is emissions related. As far as the heat shield. I did have what lltek supplied if you want to call that a heat shield. Maybe with a better made heat shield the intake would work better. The cai I made was actually really loud, I'm not really one for show and bov sounds but this thing did sound cool as hell
Old Mar 31, 2005 | 06:00 PM
geoff's Avatar
the secondary air pump is used on start up to add oxygen to the catalytic converters to help them warm up faster. It is emission related.
Old Mar 31, 2005 | 06:14 PM
  #18
TomRitt's Avatar
Ah thats what I thought, where does it get injected? Into a bung similar to an o2 sensor bung? Thats what we used on the snowmobile we built
Old Apr 1, 2005 | 04:30 PM
  #19
geoff's Avatar
It actually get injected into the intake manifold, thats why the idle is higher on cold start ups. It only stays on for about 45 seconds or so. If you look on a v6 engine the secondary air combination valve (its what allows the air to enter) is located on the backside of eash cylinder head. Its a silver canister with a vacuum line attached and a plastic or metal pipe routing to the cylinder head. (It varied on models and years) But most car makers route it directly to the exhaust system
Old Apr 1, 2005 | 04:39 PM
  #20
clconversion's Avatar
what us 2000 and 2001 guys want to knopw is there a way to rip off this pump and bypass it some how and keep those damm cels off ?
