Whats this noise?
Old May 30, 2007 | 10:42 AM
TagsAudi's Avatar
Default Whats this noise?
I've got a sort of knocking or rattling noise that i can hear when im driving and hit a bump in the road, it sounds like its coming from the front right of the car.
My thoughts were shock absorber but im not sure. Im pretty new to audi's so im not sure what else around the front right wheel areait could be.
any ideas, thanks guys
Old May 30, 2007 | 10:45 AM
acetrebo's Avatar
Default RE: Whats this noise?
Well, "knocking" and "rattling" are two different sounds, which is it?
Going over a bump, and hearing a clunking or knocking sound means your tie-rod ends are likely worn.
If you have any play in the steering at all, then this is for sure the cause of your noises.
Old May 30, 2007 | 10:48 AM
techbod's Avatar
could also be anti roll bar link rod
Old May 30, 2007 | 10:54 AM
FezA4's Avatar
how many miles on the car? ive got the same noise on both sides. sorta like a rattle?? from what i can gather from searches its the control arm bushing worn down. could be wrong... anyone??
Old May 30, 2007 | 11:53 AM
acetrebo's Avatar
Need a better description of what the noise sounds like, and any other symptoms or information.
It could be control arms, sway bar links, tie-rod ends, cv joint, wheel bearing, depending on the noise / symptoms.
Old May 30, 2007 | 11:56 AM
techbod's Avatar
do you wear ear rings ( as seen in the advert lol ) and more information required
Old May 30, 2007 | 12:11 PM
brrman's Avatar
I put my money on control arm ball joints (not the bushing which causes squeaking).
When the ball socket gets worn and stretched, the ball end of the arm knocks around in the socket when you hit bumps.
Old May 30, 2007 | 11:56 PM
TagsAudi's Avatar
car steers fine and does'nt pull to either side. steering wheels sits straight when driving and their isnt any play in it.
its more a knock knock knock sound not loud but you can hear it clearly
Old May 30, 2007 | 11:58 PM
TagsAudi's Avatar
it sounds more like a wornout bush which is causing to metal parts to know against eachother, does this help?
Old May 31, 2007 | 10:46 AM
brrman's Avatar
Have your control arms checked out - seriously.
JPJ2007
Apr 17, 2009 08:54 AM
roll4ever
May 12, 2008 11:55 PM
sickquattro915
Jun 30, 2007 01:01 PM
murphy_boy_2
Mar 29, 2006 03:00 AM
