wheel bearing
Old May 22, 2005 | 08:23 PM
mainer's Avatar
Default wheel bearing
yes i have read... but couldnt find what i was after....
it sounds like the right front... goes away (90% of the noise) above 45-50mph.
i couldnt find any write-ups on replacing it, how hard it is.... the parts seem cheap enough only $12 for teh actual bearing... but what else do i need, i have a press i can use.... but how hard is it..
also a while back i'd get a vibration out of what felt like the right rear... so how can i make sure which one it is?? without taking it all apart..?
also how long do i have before it does damage?
where do you reccomend buying the parts?
any help greatly appreciated.
97 1.8tqm
Old May 22, 2005 | 09:29 PM
david9999's Avatar
Default RE: wheel bearing
Not sure where you get a price of 12 dollars for the bearing. Generally it is in the range of 50 dollars, plus a few dollars more for associated install components. The bearing will have to be pressed in, so you will have to take it to a shop to have it pressed and then install unless you are lucky enough to have access.
Check prices for bearing at ecs tuning
Kyle_vdk
Jan 11, 2014 10:25 PM
EuroSlut
Oct 30, 2010 08:50 AM
rkh3
Dec 18, 2005 06:23 PM
