Wheel bolt size
Old Jun 2, 2006 | 11:47 PM
geForce's Avatar
Default Wheel bolt size
Hey guys
Need a bit of advice. I got a set of used 17x8 Superleggeras, but the guy I got them off said I need longer bolts. The offset is 35mm, but I didn't know a different offset would change the size of bolt I need, unless I need a spacer. Does anyone know?
Thanks.
Old Jun 3, 2006 | 12:29 AM
PandaXpress's Avatar
Default RE: Wheel bolt size
stock is 14mmX1.5b and going for longer bolts isnt a non common thing u dont want the wheel to fall off
http://www.coolcars.org/wheels/adapt...lt_Pattern.htm
Old Jun 3, 2006 | 03:49 PM
VitaminB6's Avatar
The offset doesn't matter, it's the thickness of the wheel where the bolt goes through (plus any adapter you are using). Make sure the bolt threads fully engage the threads on the hub, otherwise you'll be posting a story like this
krazzz
Mar 8, 2011 02:35 PM
Polisan
Sep 10, 2009 08:52 PM
shayrgob
Jun 4, 2009 09:21 AM
chaos92287
Dec 24, 2007 11:47 AM
