Wheel Spacers?!?!
Old May 10, 2006 | 01:04 PM
darchinova's Avatar
Default Wheel Spacers?!?!
Does anyone know the maximum size wheel spacers that would be ok for a B5 A4 on 225 wide rubber? Current offset is +45mm, and i've heard that the minimum offset you can go is +35mm, so a 10mm spacer. How about a 15mm or even 20mm spacer?
I'm going after a H&R set with the longer lugnuts, an other cheaper brands?
Old May 10, 2006 | 02:34 PM
Trey25's Avatar
Default RE: Wheel Spacers?!?!
Seen 20mm on an A4, fits well. I'm also thinking of getting 10mm up front and 15mm in the rear after I get new wheels.
Old May 11, 2006 | 04:08 PM
darchinova's Avatar
ok.. so pretty much if u make a cars offset to 0 then its ok? lol
I'm thinking 20mm on 45mm offset from 225 tires..
Old May 11, 2006 | 04:58 PM
Sp33d07's Avatar
isnt wheel spacers badd for your wheel baring?
Old May 12, 2006 | 04:03 AM
darchinova's Avatar
Whats wheel baring?
I know i might get some extra wear on the inner of the tires.. but not so sure if theres anything else to worry about?
Are spacers illegal in USA? Cos they are in Australia.. potential danger?
Old May 12, 2006 | 05:31 AM
BadLuckAudi's Avatar
yea they are hard on things and really not all that safe all i know is i would NEVER run them just get the right wheels in the first place
Old May 12, 2006 | 12:05 PM
Jestnomen's Avatar
6th Gear
Yeah wheel spacers cause undue stress. I wouln't get too crazy with large spacers.
Old May 20, 2006 | 08:43 AM
ddd's Avatar
ddd
What about a 5mm to 15mm spacer? would that also cause undue stress on the bearings?
ORIGINAL: Jestnomen
Old May 20, 2006 | 01:44 PM
Beer Mod's Avatar
^^^ Yes any spacer will but it takes along time to kill the bearing. I have 19x8.5 with 35mm offset and the sit flush if not out a lil..............
Old May 20, 2006 | 10:38 PM
DjSly's Avatar
Wow everytime I have a question someone ask it the same day :P
So I this morning I went to get a tire change since I had a bubble in the side of the tire. After raising the car I saw that both read tires had half grip and HALF SLICK !!! The metal ring was comming out .....
So I search on the reason and it seams that my drop is causing it, now that I have read this thread I<m sorta confused, I though spacers were essential when you drop your car.
I'm currently driving on Pirelli P6 P 235/45 R 17.
Any feedback would be greatly appreciated.
