Wheels~~Will they work? Please HELP!
Old Jan 30, 2008 | 10:41 AM
Crunk's Avatar
Default Wheels~~Will they work? Please HELP!
I have a New set of Konig Wheels & Dunlop Tires......I need to know if they will fit on my 2004 A4 Cabriolet. The wheels in question are : 18 x 7.5 5/100/114.45B (offset 45)
Here's the problem..........
Discount Tire doesn't show theses as being a wheel for my car and I also called them and they said they wouldn't work. BUT Today I found the Same wheels on Wheelsnext.com and they are listed as being a wheel to fit my car with the Exception of them being 18 x 8..... Does the 1/2 inch really make that much difference?
Man I lovethose wheels and I had just bought them a Month before I totalled my RX8.
I Really want to know if there is some way I can use theses wheels.
Please Help!!
Old Jan 30, 2008 | 10:43 AM
Bogie's Avatar
Default RE: Wheels~~Will they work? Please HELP!
check the hole pattern, measure your back spacing. try tirerack.com for that info. it shows up when you select a wheel and tire package.
Old Jan 30, 2008 | 10:47 AM
Crunk's Avatar
They are 5 bolt Dual slot.... I was given the impression from Discount tire that they would not be good for the weight distyribution of the car...HUH?
Thanks for the website...I will double check there
Old Jan 30, 2008 | 11:05 AM
Crunk's Avatar
FUCZK!!!!!
Looks like the Bolt Patterns specs for my car are 5-112
2Freakin' mm off!
Don't suppose they can be Machined?? Or is that a really stupid idea??
Old Jan 30, 2008 | 02:30 PM
railrunner's Avatar
wouldn't do that.
keep looking. you will find some similar or another pattern you love. sorry to hear regardless.
Old Jan 30, 2008 | 02:56 PM
Crunk's Avatar
Here is what I have...I can re-buy them again to fit the A4, But that SUX!!!!
http://www.discounttire.com/dtcs/fin...&tc=KONFUL
Old Jan 30, 2008 | 06:07 PM
qUaTtRoA4's Avatar
you can buy an adaptor/spacer that will change your 5x112 on your car to a 5x100, a nice set of 4 would prolly ber about 200-250$
gl!
Old Jan 30, 2008 | 06:22 PM
Crunk's Avatar
Thankies!
I will look into that.
I also called a Wheel Repair shop to see if they can change the both pattern 2mm.
Old Jan 30, 2008 | 07:46 PM
khj677turbo's Avatar
your stuck on those wheels[:'(]
Old Jan 30, 2008 | 09:59 PM
Crunk's Avatar
Maybe stuck with them...if I can't sell them
I know...I know, I do like the 2 tone wheels...not too flashy and not solid black.
