when adjusting rebound....
Old Apr 26, 2006 | 10:29 PM
rons01a4's Avatar
Default when adjusting rebound....
on my koni coilovers, do i turn the alen key to the right to increase rebound? the second click should be 50%, right?
Old Apr 26, 2006 | 11:24 PM
trailboss's Avatar
Default RE: when adjusting rebound....
To increase rebound i believe it was 4 revolutions to complete stiff. 1 revolutin = 25% stiff 2 = 50% stiff 3 = 75% 4 = full stiff. You have to fully compress the strut to adjust it and you will feel when it is full stiff, it will hit a stop. Then you have to pull it back out and reasamble the upper mounting plate and so on. Use a bench vise to pull it back out.
Old Apr 26, 2006 | 11:25 PM
trailboss's Avatar
When they sent you the coil overs they send them at OEM settings. Using a stiffer spring the rebound should be increased, i sen mine at front 80% rear 90%.
adam044
Aug 2, 2014 11:33 AM
nrowensby
Jun 4, 2008 08:57 PM
rons01a4
Mar 28, 2006 05:21 PM
jayA6
Sep 7, 2005 01:07 AM
