Key will not rebound after start
Old Sep 4, 2005 | 11:50 PM
jayA6's Avatar
Default Key will not rebound after start
i have a '96 A6 2.8L. my problem is that once you start the car and let go of the key, the key does not spring back. i have to manually turn it back. does anyone know how i can fix it? thanks......
Old Sep 5, 2005 | 02:16 AM
dan908's Avatar
Default RE: Key will not rebound after start
Someone just asked this question yesterday.
But love responding so...
It is your ignition switch. The things are total pieces of crap in my opinion. Should be a totally different set up. An ignition switch is basically the piece behind your key that controls whether the power is on off etc. It is on a spring.
The switch is made of plastic and that is what fails. It is about a 30 dollar part you can buy it at any vw or audi dealer. Or order it online. blauparts.com has the part and instructions on how to put it in. Never have used them but some say they are cool.
To put it in, You pull out your gauge cluster three screws in the bottom of the gauge retaining piece pull that out (slightly cocked to the left (there is a pin) then two or three screws on the gauges. Behind the area of the dash you put your key in there is a white plastic cylinder that is it. I never did figure out how to remove mine with out destroying it so good luck. From what I could tell there is a retaining screw that i never found. Should just slide in/ out and be one wire that you transfer over.
Old Sep 6, 2005 | 10:25 PM
jayA6's Avatar
Thanks for the info......
Old Sep 7, 2005 | 01:07 AM
beefski's Avatar
first i would try some graphite it may just be stuck.
rons01a4
Apr 26, 2006 11:25 PM
rons01a4
Mar 28, 2006 05:21 PM
