where can I tap into power?
Old Nov 9, 2005 | 06:07 PM
kleinma's Avatar
Default where can I tap into power?
Hello all,
I have a 2004 Audi A4 (1.8T 6 speed if it matters)
I have a valentine one radar detector along with the hard wire kit for it so I don't need to use the power outlet plug.
I used to have this hooked up in my celica and it was really easy to implement because that car came apart a little easier than the audi. I was able to tap into the stereo power for it.
Does anyone know a good spot to tap into 12v power and also a good ground spot near by that? I can go to the fuse box if I need to, but fuse taps are ugly and messy and if possible I would like to tap directly into a wire.
Thanks
Old Nov 9, 2005 | 06:42 PM
huyaroo's Avatar
Default RE: where can I tap into power?
Check here: http://www.audiworld.com/tech/elec32.shtml
He used the rear wiper fuse slot to put it in his car. The instructions are for a 1999 but it might work for yours too.
Old Nov 9, 2005 | 06:43 PM
GregC's Avatar
On my car (Right Hand Drive) open the drivers door, there is a panel that is exposed at the side of the dashboard, this comes off and below it is the Fuse Panel. You can easily tap power and get an earth from there.
Greg
Old Nov 9, 2005 | 07:29 PM
audilover04's Avatar
^^^^^^^^^^^^^^^^^^^^^^ yup, i didn't instal my V1 my self but i watched the guy do it the whole time to make sure he didn't cut corners, etc. The panel on the side of the dashboard on the drivers side.
suuntotim
Jul 25, 2011 12:36 PM
99BlackA4
May 22, 2006 08:43 PM
