Where does this Vac Line go?
Old Apr 18, 2007 | 04:34 AM
jrodpikap's Avatar
Default Where does this Vac Line go?
Anyone know what this Valve is and why there is a screw plugging it? Trying to figure out where the vac line that should be there is supposed to go...anyone have an idea? It is located under the Intake Manifold and above the Alternator. Thanks.
Front View (with screw in one side):
Back view (with 2 vac lines running in):
Old Apr 18, 2007 | 02:46 PM
cincyTT's Avatar
I'm make believe
Default RE: Where does this Vac Line go?
It has a check valve on it so it should be attached to something important. If its under the intake manifold it probably was originally attached underneath it. See where the other side of the line comes out.
Old Apr 18, 2007 | 07:26 PM
smokeU's Avatar
diverter valve i think.
Old Apr 18, 2007 | 08:36 PM
cincyTT's Avatar
I'm make believe
ORIGINAL: smokeU
wrong side of the car.
Old Apr 18, 2007 | 11:03 PM
Pablo_Ottawa's Avatar
Dude, take some shots further away so we can see the entire engine and orientate ourselves. draw a little arrow thingy and type in "you are here" lol
Old Apr 19, 2007 | 01:14 AM
jrodpikap's Avatar
Here you go...in the first pic, you can't see the valve, or screw b/c it's hiding under the manifold, but it receives this vacuum line on the right side:
Here is abetter view showing the screw-plugged left end going to???:
Old Apr 19, 2007 | 01:28 AM
cincyTT's Avatar
I'm make believe
I would check underneith the manifold (if you havnt yet) and see if there is a open nipple. If you have a boost guage, what is your vacuum at? Also, where is that hoses going to?
Old Apr 19, 2007 | 01:38 AM
jrodpikap's Avatar
No boost gauge...i'll have to look under the manifold tomorrow and see if I can find something. I wish I knew someone around here with a 1.8T...so I could compare.
Old Apr 19, 2007 | 02:15 AM
98A4TQ's Avatar
that vac line connected to the front of the intake manifold should be going to the DV. Looks like a boost guage was once installed then removed, so the line that was tapped in for the boost guage is now plugged up.
Old Apr 19, 2007 | 02:20 AM
cincyTT's Avatar
I'm make believe
that sounds plausable.
